1999 Vauxhall Astra EOBD Code P0200,
90,000 MILES • 4 CYL • 2WD • MANUAL
AZEE13
  • 10 POSTS
Hi, I pluged my Astra in to a EOBD reader and found out that Injector Circuit Malfunction. When I checked Injecter circuit it was loose and i used a cable tie to tied it up. No more ecu icon on my dash board but now i feel my car not as smooth as it was, i feel its rough and missing. what could be the problem. can anyone hel me please. Thank you.
Jul 5, 2009 at 7:01 AM
DAVE H
  • 13,383 POSTS
A miss could be caused by numerous things ... if it is indeed missing it will bring on the MIL again and another code will reveal the fault source .. hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_851.png
Jul 5, 2009 at 10:26 PM
AZEE13
  • 10 POSTS
Hi thank u for your reply. it really was helpful. As the engine mis is not very strong but i feel itis bit rough. there is no other problem. Any idea what it could be?
thank you again.
Jul 6, 2009 at 5:14 AM
DAVE H
  • 13,383 POSTS
re-check the injector is firing ...add a good fuel cleaner to the tank to clean the injectors .. it may have dirt/grime stuck in one !! also it could be a bad coil/plug/lead or even the CKP(cramkshaft postition) sensor being worn/dirty causing the miss !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_853.png
Jul 6, 2009 at 11:51 AM
