1998 Vauxhall Astra engine lacks power
MOSER
  • 1998 VAUXHALL ASTRA
Engine Performance problem
1998 Vauxhall Astra 4 cyl Front Wheel Drive Manual 108ooo miles
hello ive recently done the head gasket on my 2ltr dti astra. Ive timed it up with the correct pins. However the turbo works, but the engine lacks power. Also it takes a while to start in the mornings. The engine does seem to be a little noiser as well, and every know and then usually first thing all power is resumed, any ideas? Regards keith
Friday, March 20th, 2009 AT 6:24 AM
DAVE H
  • 13,384 POSTS
Check the exhaust manifold for leaks .. you could be losing compression and this would make the engine sound a little louder !!
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_313.png
Friday, March 20th, 2009 AT 7:46 AM
