1998 Vauxhall Astra clutch
1998 VAUXHALL ASTRA
135,000 MILES • V8 • 2WD • MANUAL
LIAM ROCHE
hello.just wandering whats happend to my clutch its gone all loose on biting point and it wont go it to gear the rac bloke said he thought the celinder?was knackered its been held in by cable tie,he said wen he bleed it air just came out of it not no fluid but he filled it up i was just wandering what u thought and what i need to do to sort it cheers
Jan 22, 2009 at 9:22 PM
DAVE H
  • 13,384 POSTS
check thewhole clutch system .. master cylinder,slave cylinder and pipes for leaks .. also replace the slave cylinder ... if this is the one held on by cable tie !
Jan 31, 2009 at 1:08 PM
