1997 Vauxhall Astra knocking
61,495 MILES • 4 CYL • FWD • AUTOMATIC
ANDJAM38
hi i recently purchased astra 1.6 16v auto that, i was told the head gasket had gone its has an lpg conversion on it, anyway i started the engine before proceeding to strip the head it took a lot of starting and when it did it ran as if it was missing and when i revved it there was a knocking sound from topend i think what could this be please could you help i have now started stripping head down to have it pressure- tested and skimmed also could you tell me of a good guality head gasket and timing belt? thankyou Andy James
Nov 7, 2010 at 7:11 AM
DAVE H
  • 13,383 POSTS
Dealer (oem) parts are always best ..you should discover the cause of the topend knock once you have the head off .. I would advise replacing the water pump and timing belt tensioner as well
Nov 9, 2010 at 12:13 PM
