1996 Vauxhall Astra oil top up
92,925 MILES • 6 CYL • 2WD • AUTOMATIC
DENNIS1953
put to much oil in gearbox now lots of white smoke got a friend to drain to normal level left engine running to burn off excess oil from exhaust but still lots of white smoke what can ido to stop this problem
Feb 19, 2010 at 9:04 PM
  • 75,988 POSTS
If its burning oil the color should be bluish-White smoke indicates coolant/water burning
Feb 19, 2010 at 10:25 PM
DAVE H
  • 13,383 POSTS
too much oil in gearbox will not cause the engine to smoke ... check cylinder compression .. suspect haedgasket failure .. a common fault on this vehicle
Feb 21, 2010 at 9:31 PM
