1995 Vauxhall Astra radiator fan
127,000 MILES • 4 CYL • 2WD • MANUAL
HBOMB1805
I bought this car as a cheap runaround and it's overheating when driving in stop start traffic..I'm assuming this is the fan not coming on as it seems to be OK on open roads. If it is the fan is there any reason that I couldn't just wire it straight into the battery so that it is on all the time, rather than bother with replacing coolant temperature sensors and what-not?
Jun 10, 2009 at 8:04 AM
DAVE H
  • 13,383 POSTS
you could wire direct to battery ... but you would have to install some kind of switch on the system or it would run down the battery when the vehicle is not running !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_776.png
Jun 10, 2009 at 11:13 AM
