1995 Vauxhall Astra Fan issue
GREGMONA
Heater problem
1995 Vauxhall Astra 70k miles
Hi
I have a problem with fan in my car.
I does not working on first and second stage, it's starting to work when I put it on 3rd or 4th but then the air is blowing to strong and it's disturbing.
what is the reason??
is it possible to pull the switch out of the conrol panel to check the connections and how??
Oct 20, 2009 at 4:18 AM
DAVE H
  • 13,383 POSTS
check/replace the resistor located on the heater unit housing .. Your local autoparts store will be able to supply a repair manual with step by step instructions on the repair !
Oct 20, 2009 at 8:02 PM
