1993 Vauxhall Astra Astra sxi 1.8 fuel pressure regulator
95,000 MILES • 4 CYL • 2WD • MANUAL
JC1520
Hi Guys i am desperate to find a fuel pressure regualter for a Astra 1.8 sxi J reg do any one have any info on what spec it needs to be the one on the car is coroded badly and i have no info from it i am sure this is a common problem as it is located near rear wheel arch and exposed so it will be coroded almost in the first few years of its life i can buy one from vauxhall but it is mega expensive any info on a direct replacment from another source would good thank u
Oct 17, 2009 at 9:07 AM
DAVE H
  • 13,383 POSTS
most local autoparts stores will be able to source the part for you ..or you could try the astra owners club website !!
Oct 20, 2009 at 8:11 PM
