1993 Vauxhall Astra AIR BAG WARNING LIGHT - RESET
1993 VAUXHALL ASTRA
88,000 MILES • 4 CYL • FWD • AUTOMATIC
NATKIN
In my ignorance I disconnected the airbag from the steering wheel attempting to diagnose a horn button problem.
I did disconnect the battery before removing the airbag assembly but from what I have since learned I should have waited at least 30minutes? before disconnecting the airbag assembly.
I subsequently reconnected the airbag assembly since which time the airbag dashboard facia warning light stays on all the time.
Can I reset the airbag assembly and/or warning light or will it mean a trip and exorbitant costs to the Vauxhall dealer.
Regards
Dec 25, 2008 at 4:16 AM
DAVE H
  • 13,384 POSTS
try removing battery cables for five minutes then reconnecting ... if this does not work theres is a fault on the wiring somewhere and your better of letting a tech do the work .. most garages will do this for you.. does not have to be a dealer ..
Jan 21, 2009 at 1:18 PM
