I'm having the following electrical (I think) problems that may prevent me from passing the PA state inspection. I'd appreciate your help.
-The gear display on the steering column doesn't illuminate, making it impossible to see in the dark
When I shift into reverse.
-Sometimes, when I shift into reverse, I get the backup lights and the beeping and sometimes I don't. But if I jiggle the shift lever a bit it comes back on. What do I need to do to ensure that it always stays on?
-The hazard switch is inconsistent in behavior. Generally, I have to push it in really hard to get a consistent flash and then it SOMETIMES stays in and sometimes it doesn't. Is there anything I can try short of taking apart the steering column to restore proper function.
Oh, here's one that's not electrical. I have a rusted out battery tray. What would be the easiest and cheapest safe way to do a replacement?
Thanks. You guys are awesome
Nov 14, 2014 at 6:03 AM
