my car is making a grinding noise when i turn, is it my loints or steering colum or the whole front axle?
Mar 21, 2006 at 5:52 AM
UNOWHO444
MEMBER
what model car do you have? is the noise comming from left or right turns or both? with the car parked you can turn your steering wheel all the to the left and look at the rubber boot (cv axle boot) to see if it is cracked opened and has grease comming from it.do this also with the other side.if so you will need to replace the cv axle.
Mar 25, 2006 at 12:38 AM
