variable timing control sensor
120,000 MILES • 1.8L • 4 CYL • AUTOMATIC
REDGITTL
how to do a benchmark test for variable timing control sensor?
Aug 25, 2017 at 8:17 AM
STEVE W.
  • 15,418 POSTS
About the only way is to use a scan tool and an oscilloscope on the cam and crank sensors and watch the wave forms move as you cycle the cam phasing with the scan tool. Then you could see if IATN or Pico have a good known waveform to compare it.
google - Low Power case study: Chevy Equinox - Parts 1 and 2 Pine Hollow.
Ivan shows the hook ups and tests.
Aug 25, 2017 at 9:35 AM
REDGITTL
looking for the color of the three wires for coil 1,2,3,4. do you have that? Changed the ECM but need this before I connect temperature sensor. Thanks in advance.
Aug 26, 2017 at 4:35 PM
STEVE W.
  • 15,418 POSTS
This is the ignition wiring.
Aug 27, 2017 at 3:17 AM
