Variable camshaft issue?
370,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
TAHOE'N_IT
One day I stopped at a gas station, and it wouldn't start once I was done pumping gas. No noises or odd symptoms beforehand. Codes referred to an issue with the VVT solenoid and that both bank 1 and 2 were too lean. It cranks but acts like there's no spark. I wanted to test the camshaft position sensor to start with but have not been able to find it or the VVT. I've searched online and can't find a good picture or reference. Thanks for any help.
Nov 17, 2024 at 6:42 AM
  • 110,248 POSTS
The camshaft position sensor is located at the top rear of the engine (see picture below). This vehicle doesn't have variable valve timing solenoids.
The lean fuel mixture on both sides could be a few things. I need you to try something. See if the engine will start if you use starting fluid. If it does and then stalls, it sounds like the fuel pump has failed. If that isn't the case, I need you to check for ignition spark.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find.
See pic below.
Nov 17, 2024 at 1:22 PM
TAHOE'N_IT
So it wouldn't start with starting fluid, and I checked for spark which there was. I located the CPS and replaced it. When I went to start it, it started right up so I gave myself a pat on the back and went to bed. This morning it started right up but when I got a mile or two from the house and the engine started to warm up it died while I was driving and won't start again. Not sure what to do next.
Nov 18, 2024 at 10:43 PM
  • 55,710 POSTS
Lets check for spark again to see if it is still there, please go over this video which will help you see what's going on and how to test for spark. I have seen the engine run low on engine oil and cut the spark off so please check that first.
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
Please upload pictures or videos in your response of any problems so we can see what to help you with.
Nov 21, 2024 at 1:33 AM
