Based on your description, I feel either you are losing spark or fuel. I have to be honest, a bad crankshaft sensor will act this way when they get hot. What I need you to do is check if the engine has spark and fuel when it is refusing to start. Something tells me you will find there is no spark. I will attach links which explain how to check both; however, the first link is related to a crankshaft sensor and how they act when they start going bad.
Read through these and let me know if you have questions.
Here are general directions for replacement if you find it is the problem:
These are the links which show how to check for both spark and fuel. Do this when it refuses to start. Let me know what you find.
Let me know if this helps or if you have questions.
Jul 14, 2018 at 12:22 PM
