Van turns over and starts but only runs for about 3 seconds
122,763 MILES • 0.6L • 6 CYL • AWD • AUTOMATIC
KIRSTEN SHERLOCK
So my car was stolen luckily I got it back but unfortunately the problem I'm having is because they ripped out the ignition and it has a security system on it and they lost the key I have replaced the ignition switch cylinder and key it will turn over and crank and start up for about 3 seconds then dies I have put in the codes and reset the security system several times but it is still messed up please help is there any way I can bypass this with a toggle or anything like that
After it starts the second it dies there is this sound up by the break booster it sounds kind like there is a air leak or something. I don't know if that has anything to do with my issue.
May 16, 2017 at 7:19 PM
HMAC300
  • 48,601 POSTS
the security system won't reset on this until you have the ignition switch andkey programmed by a mechanic with a scanner. then it will work. so tow it to a shop to do that.
May 17, 2017 at 12:03 AM
KIRSTEN SHERLOCK
People with tons of money have that as an option i don't so I need to know how to go about bypassing the security system or disabling it
May 17, 2017 at 4:18 AM
HMAC300
  • 48,601 POSTS
you'll have to look online for that but most of the newer security systems are not by passable. call around to mechanics see how much it will be I tmay not be tons of money to fix.
May 17, 2017 at 5:00 AM
