Van stalls when we put it in reverse and drive
280,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
COOLHAND68
I was driving down the road and my van (listed above) started to shake and jerk, leveled out. so I got it up to 40 mph came to a stop light, when light turned green I hit gas and suddenly there was a whirring noise and I couldn't go any faster than first gear. Parked it had it towed home. We changed the transmission filter, the whirring noise went away, but when we put it in reverse it shuts off. If you go to neutral it stays running but in drive it stalls.
Nov 3, 2019 at 8:34 AM
MASTERWRENCH
  • 258 POSTS
Unfortunately the condition you're describing is the result of a failed torque converter clutch (in the transmission). The converter clutch typically engages at higher speeds, mostly for fuel economy purposes. In situations where the converter clutch gets stuck or stays engaged all the time, the vehicle will act very much like a manual transmission when you fail to push the clutch pedal in when coming to a stop. Normally replacing the torque converter fixes this issue, but based on the symptoms you experienced just prior to this, there's a strong possibility of further internal transmission damage. I would suggest having the vehicle evaluated by a transmission specialist.
Nov 3, 2019 at 12:12 PM
