Van not starting
230 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
BRIAN POWELL2
  • 10 POSTS
My van will not start. what would be the problem?
Dec 23, 2017 at 12:24 AM
Good morning my name is Roy and I will assist.
You need three things for it to run. Spark, fuel pressure and compression.
Try spraying some carburetor cleaner into the air filter and see if it starts and stalls.
Also, is the battery working?
Aug 30, 2020 at 5:28 AM
BRIAN POWELL2
  • 10 POSTS
Yeah, the battery is working.
Okay, then try the starting fluid and see if it starts and stalls. that will tell us it is a fuel delivery issue.
