Van leaks , oil or gas
100,000 MILES • 3.6L • 6 CYL • FWD • AUTOMATIC
ANGIE CAMPBELL
Especially when it rains we see a leak on the ground, especially when applying the brake and/or turning around a corner .
We cant figure out where it is coming from, Just recently changed the Transmission pan , but it hasn't made a difference.
We racked up approx $1000 taking it to get wrongly diagnosed. Please help
Apr 19, 2017 at 2:34 AM
HMAC300
  • 48,601 POSTS
with rain it's kind of hard to diagnose, but see what fluid is going low other than gas. to check for fuel leak start up van and try to rock it to simiulate when it drips, it may be just water you are seeing from the rain. brake fluid will normally go down in master as front brakes wear so be aware of that.
Apr 19, 2017 at 2:52 AM
