Van has no power
12,200 MILES • 5.0L • V8 • 2WD • AUTOMATIC
RENEGADE5
I have replaced catalytic converter and muffler, throttle position sensor. idles good. when you give it gas bogs down.
Codes are:
99
81
13
Aug 14, 2019 at 10:16 AM
94 TRANSAM
  • 680 POSTS
Hi, thank you for using 2CarPros. Lets see if we can straighten this out for you.
Your code 13 is probably caused by your code 81 which is a bad idle air control solenoid.
As for the code 99. I find no listing for a code 99. Could it be a different number?
Rich
Aug 14, 2019 at 12:30 PM
