Van shut off while driving, now it cranks but will not start
175,000 MILES • 3.0L
WILLIAMS1927
  • 9 POSTS
So I took the alternator out found out it was bad. Replaced it and now it still just cranks. so I replaced a cam sensor b and a crank sensor and my van still just cranks. van was running good until it abruptly shut off while in motion. does anyone have any section in something to test or try? please let me know
Thanks, Matt
Jul 28, 2019 at 9:17 AM
SCGRANTURISMO
  • 4,897 POSTS
Do you have fuel pressure at the fuel rail? Have a helper turn the ignition key to "run" while you listen at the fuel tank for the fuel pump to come on and prime the fuel system. Please get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 28, 2019 at 9:57 PM
WILLIAMS1927
  • 9 POSTS
I literally drove 5 minutes from my house then on the way home it shut off. fuel tank is almost full and I’m pretty sure I can it buzzing and working.
Jul 28, 2019 at 10:08 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Can you verify that it is getting spark for us. Here is a link below for you to go to:
Please go through this guide and get back to us with what you are able to find. We will go from there.
Thanks,
Alex
2CarPros
Jul 29, 2019 at 7:48 AM
