What is the firing order for this engine?
128,000 MILES • 1.2L • 4 CYL • 2WD • MANUAL
MARLIZE WESSELS
Kindly assist as in giving the right opening valve order for the car listed above.
Oct 3, 2021 at 7:40 PM
Good morning,
I attached the firing order for you to view in specifications.
There is no diagram for valve movements for the motor.
The engine opens an intake valve for fuel/air mixture to enter on the downstroke. Then the valve closes, and the upstroke compresses the mixture until the spark ignites it. Then the power stroke forces the piston down. When the piston comes back up, the exhaust valve opens, and the burnt mixture is sent out to the exhaust the process starts again.
Oct 3, 2021 at 8:14 PM
MARLIZE WESSELS
Thank you for the reply.
Oct 4, 2021 at 4:32 AM
You are welcome.
Let us know if you have any other questions.
Oct 4, 2021 at 7:56 PM
