valve timing marks on engine code AML
250,000 MILES
CHITOWE
i am replacing timing belt on audi a6 AML engine and i need the diagram for timing marks and the procedure for the work. the car has a whining noise problem on engine front and overheating. the noise seems to be coming from idler pulley on belt tensioner . water is not circulating in yhe engine because when it boils the lower radiator hose is cold and the upper hose is too hot so i thought of checking if the water pump impeller collapsed. to do this the timing belt had to be removed.the pump is ok so it could be a faulty thermostat,or what do you think
May 30, 2013 at 3:54 PM
EXOVCDS
  • 1,882 POSTS
Let me know if you still need information.
2carpos no longer sends me emails when someone replies to me. You can find me through my user profile.
Thomas
Jun 1, 2013 at 7:28 AM
SEANGRANT00
  • EXPERT
  • 334 POSTS
It sounds like a thermostat. What size engine do you have?
Jul 8, 2013 at 7:48 AM
