Valve repair
1999 SUZUKI ESTEEM
8 MILES • 4 CYL • FWD
MOA JAMIR
I have repair valve and install it back, but the engine ignition does not work. Regarding the timing belt and valve I have adjusted it according to your YouTube, but it does not work and the car temperature shows maximum when I switch on the air conditioner. Please advise.
May 1, 2016 at 10:24 PM
  • 31,937 POSTS
i would be re checking the valve timing, if you have had to re adjust after a start attempt, i would suggest a compression test as well just to eliminate and further vale damage that may have occurred if the valve timing was incorrect in the first instance.
May 2, 2016 at 7:36 AM
