the check engine light, flashes on and off
132,234 MILES • 5.3L • V8 • 2WD • AUTOMATIC
SILVERADODUDE
Hesitation upon acceleration, and a lot of white smoke comes from the exhaust pipe. Tried a tune up, got the same problem; and the check engine light, flashes on and off. It never had a problem starting, first time, everytime, just the hesitation and smoke.
Feb 13, 2021 at 12:36 PM
Good morning,
White smoke is an indication of a failing head gasket. You are burning coolant in the combustion chamber but to be sure we should get the codes. This video shows the job being done on a similar car but the process is the same.
https://youtu.be/v0ayZE5kq1Y
and
The hesitation may also be th result.of the head gasket. Please run down these guides and report back.
Feb 13, 2021 at 10:11 PM
