valve lash
140,000 MILES • 3.1L • V6 • FWD • AUTOMATIC
REDMAN4496
I replaced head gaskets I got it all back together, but one or more lifters are tapping. I replaced one bad lifter, what did I do wrong?
Mar 19, 2016 at 12:54 PM
HMAC300
  • 48,601 POSTS
Maybe nothing was done wrong, but sometimes lifters will collapse when doing this type of repair. Try running transmission fluid in it for about 100 miles or so, then change oil and filter. It may cure it, if not you haven't lost much as far as a repair that way. It may have got some dirt in it as well from the repair.
Mar 19, 2016 at 1:24 PM
HMAC300
  • 48,601 POSTS
One thing I forgot, you can try to readjust the lifters as well. If the head was resurfaced you might try shimming bolt to get to correct height.
Mar 19, 2016 at 1:28 PM
