valve job
1998 ISUZU RODEO
MAGIC62874
I drove my rodeo to the shop for a small water leak and it was running great. Found the leak at the waterpump, so they changed the waterpump and timing belt. Now they called and said I had to have a valve job it lost compression. How could it go from running great to lost compression just from changing the parts?
May 26, 2013 at 8:13 PM
they may have installed the timing belt in correctly and bent the valves.
May 26, 2013 at 9:41 PM
MAGIC62874
now they are saying the valve burnt out.Would that be from the same thing? They have had my truck for a month and a half now.Just don't know whats going on?
May 26, 2013 at 9:45 PM
MAGIC62874
They also said they broke some bolt and are having to drill it out.
May 26, 2013 at 9:50 PM
1 valve??? it would run if that was the case,it sounds like they are covering up for there mistake
May 26, 2013 at 10:09 PM
MAGIC62874
Thats what i was thinking.Just wasn't sure. Thanks alot for your help.
May 26, 2013 at 10:18 PM
