Valve cover or valve cover gaskets leaking
70,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
IRVING81368
I had all my valve cover gaskets replaced. I am still having a link of oil on the rear valve cover gasket. Is it that my valve cover maybe warped? on the reason why I'm still having this leak. I understand the valve covers on my vehicle listed above are plastic. Or do you think I have a hairline crack in the head? I'm not having any symptoms of a cracked head. I only had the car for 3 weeks. Can you help?
Apr 7, 2022 at 4:47 AM
  • 110,248 POSTS
Certainly, either of the two things you mentioned can cause a leak. However, a leaking spark plug tower seal can cause it or if the cover was improperly torqued when it was reinstalled.
Did you replace the gasket? If so, did you use a gasket or gasket maker?
I know this is a bigger job. If you plan to replace the gasket again, you may want to consider replacing the plastic cover just in case it is cracked or warped.
take care,
Apr 7, 2022 at 11:37 AM
IRVING81368
Thanks for your response. I had all valve cover gaskets replaced. I didn't replace the valve cover. This is what I'm going to do next, but I don't have any signs of a cracked head. I only have 70,000 miles on the vehicle listed above. Sense I have no signs of a cracked head, can I rule that out?
Apr 7, 2022 at 11:56 AM
  • 110,248 POSTS
I feel very confident it isn't a head. In most cases, it is exactly what you suggested, a warped cover.
Let me know if I can help in any way.
Apr 7, 2022 at 1:18 PM
IRVING81368
Thanks again, I will let you know the ending results. Thanks
Apr 7, 2022 at 1:19 PM
  • 110,248 POSTS
You are very welcome. I'll watch for your reply.
Take care and let me know if I can help in any way.
Apr 7, 2022 at 1:25 PM
