Valve cover torque specs ? V6 3.4L 1988?
100,000 MILES • 6.4L • AUTOMATIC
PAPACASTOR
  • 7 POSTS
Je veux avoir le torque pour visser le couvert de valves que l'on voit en haut du moteur.
I want to know the torque setting for screwing on the valve cover that can be seen at the top of the engine.
May 15, 2026 at 3:39 PM
  • 55,694 POSTS
Sure,
Torque spec: 106 inch-pounds
That equals about 9 ft-lbs or 12 N·m. A GM 4.3L service torque chart lists the valve rocker arm cover bolt at 12 N·m / 106 lb-in.
Let me know if you need anything else.
May 17, 2026 at 9:28 AM
PAPACASTOR
  • 7 POSTS
Merci beaucoup, c'est très apprécié. Bonne journée
May 18, 2026 at 7:50 AM
  • 55,694 POSTS
De rien, faites de même.
May 19, 2026 at 7:15 AM
