Can I get the Valve cover torque sequence and spec?
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
RYUREI4444
  • 6 POSTS
I'm replacing the valve cover gasket; I need to know the correct torque sequence and spec for the bolts.
May 7, 2023 at 1:35 PM
  • 110,246 POSTS
I attached the directions for installing the valve cover. See pics below. When you do it, make sure that all the old sealant is removed.
Take a look at the directions and let me know if you have questions. Note that the directions do not indicate a sequence. In this type of case, start at center and working left to right, work your way out to the outside ones.
See pcs below.
May 7, 2023 at 3:13 PM
RYUREI4444
  • 6 POSTS
I'm going to replace the gasket on the vacuum pump as well, could you also share the directions for that?
May 7, 2023 at 3:31 PM
  • 110,246 POSTS
I attached the installation directions below. The torque is done in two steps. I highlighted the info in pic 3.
Let me know if this helps.
May 8, 2023 at 11:19 AM
