Valve cover torque
192,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
JPRIVETTE
I can't seem to find the valve cover torque for my car. I can find instructions online how to change the gasket, but not what to torque it down to after I'm finished.
Apr 11, 2019 at 8:04 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Not a problem. You came to the right place. However, you indicated this as a 1.4L. I believe you meant 1.6L because a 1.4L, to the best of my knowledge, wasn't offered.
With that in mind, here is what I have. Let me know if you need anything else.
Mechanical
Vehicle Engine, Cooling and Exhaust Engine Cylinder Head Assembly Valve Cover Specifications Mechanical
MECHANICAL
Bolts .................... 5.9 Nm (52 inch lbs.)
Note: Make sure not to over tighten. The torque is in inch pounds and not foot pounds.
Let me know if I can help.
Apr 11, 2019 at 11:55 AM
JPRIVETTE
Thanks for your help Joe. Do you happen to know the sequence to use when tightening them back down? BTW, it's actually a 1.8, but thanks to a phone glitch it was entered wrong and I don't know how to change it.
Apr 11, 2019 at 1:54 PM
  • 110,248 POSTS
Welcome back:
My manual doesn't provide the sequence. Start in the center and work in a crisscross motion. Snug them all first, and then do the final torque.
I confirmed the torque is the same for the 1.8L.
Let me know if you need anything.
Apr 12, 2019 at 12:48 PM
