valve cover gaskets replacement
265,000 MILES • 3.1L • V6 • 4WD • AUTOMATIC
CHYANNE SHERIFF
  • 85 POSTS
i need to know how to change valve cover gaskets. how many gaskets on the car and if you have a diagram to show me to go by? would it be expensive to have a mechanic do the job?
Jan 28, 2018 at 12:45 AM
CARADIODOC
  • 34,415 POSTS
Here is a guide that explains the procedure:
https://www.2carpros.com/articles/replace-valve-cover-gasket
Your engine uses two valve cover gaskets. Be aware these are a molded rubber gasket. Very often minor oil leaks can be solved by tightening the valve cover bolts a little.
Jan 28, 2018 at 10:25 AM
