Valve cover gaskets replacement
137,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
RIEBE123
  • 46 POSTS
My valve cover gaskets are leaking moderately. I am due to replace both of them. my question is, when I replace the tube seals do I use any Honda bond? also when I replace the gaskets do I use any Honda bond?
A lot to take off so I want to make sure they both are sealed well.
Mar 2, 2019 at 7:00 AM
D6SPAN
  • 58 POSTS
Hi Riebe,
Some say that using a RTV for an application like this isn't necessary, however, I usually use Permatex Ultra Black (same thing, different name). I use it on the tube seals and on the gasket. Just be sure you don't use so much that it makes a mess under the valve cover. You got this!
Here is a guide to help step by step with diagrams below to show you how on your car
https://www.2carpros.com/articles/replace-valve-cover-gasket
Mar 2, 2019 at 8:49 AM
DAVE1310
  • 64 POSTS
Thanks. that is exactly what I need to know.
Mar 2, 2019 at 9:52 AM
  • 55,808 POSTS
D6SPAN is quickly becoming one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Mar 5, 2019 at 3:18 AM
