Small leak in the valve cover gasket
172,000 MILES • 6 CYL • AUTOMATIC
THE KID
i had a mechanic look at my car said i have a very very small leak valve cover gasket but no oil is leaking. should i be concerned or is this a major problem?
Mar 4, 2020 at 7:18 AM
CJ MEDEVAC
  • 11,000 POSTS
What is leaking out of the cover?
The Medic
Mar 4, 2020 at 7:31 AM
Good evening,
If you are using any oil and there is no leak showing, I would wait until it needs to be done.
Did he say which one was leaking?
Cylinder Head Cover Removal
1. Remove the intake manifold See: Intake Manifold > Removal and Replacement > Intake Manifold Removal/Installation.
2. Remove the six ignition coils See: Ignition Coil > Removal and Replacement > Ignition Coil and Spark Plug Removal/Installation (Except J35A7).
3. Remove the dipstick.
Front Cylinder Head Cover
4. Remove the two bolts (A) securing the harness holder, and remove the harness clamp (B).
Rear Cylinder Head Cover
5. Remove the drive belt See: Drive Belt > Removal and Replacement > Drive Belt Replacement (J35A6).
6. Remove the power steering (P/S) pump and the P/S hose bracket See: Cylinder Head Assembly > Removal and Replacement > Cylinder Head Removal (J35A6) with its hoses connected.
7. Remove the harness holder mounting bolts (A) and the engine ground cable bolt (B).
8. Disconnect the injector connectors (C) and the two harness clips (D).
9. Remove the engine ground cable (E) and disconnect the breather hose (F).
10. Remove the harness (G) from the upper cover.
11. Remove the cylinder head cover.
FRONT
REAR
Mar 4, 2020 at 7:34 AM
