Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Sentra
Engine
Cylinder Head
Valve Cover
Gasket
Valve cover gasket 1.8L aluminum cover
2005 NISSAN SENTRA
250,000 MILES
PELON14
MEMBER
1 POST
Torque specs 1.8L aluminum cover ?
Jan 4, 2026 at 3:13 AM
Experienced Mechanic
So here is the info needed
Torque: 7.2 ft-lb (10 Nm / 87 in-lb)
These bolts are very easy to strip in the aluminum head, use an inch-pound torque wrench if you have one. Let us know if you need anything else.
Jan 5, 2026 at 2:38 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
