Valve cover torque specifications
2011 CHEVROLET AVEO
83,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
MIKE821
I need the torque specifications for the valve cover so I can put a new gasket in. Also does it need to be torqued down in a certain sequence? Thank you
May 26, 2019 at 2:16 AM
KENW1
  • 213 POSTS
Thanks for visiting 2CarPros.
Chevy does not specify a sequence on this. I recommend working from the center out in a criss cross pattern. Torque spec is 70.8lb in
Below is the factory procedure
Removal Procedure
1. Disconnect the battery negative cable. Refer to Battery Negative Cable Disconnection and Connection (See: Negative > Removal and Replacement).
2. Disconnect the related sensor and actuator connector and pull engine wiring harness aside.
3. Disconnect the oil switch wiring connector.
4. Disconnect the A/C compressor connector.
5. Disconnect the manifold air temperature (MAT) sensor connector.
6. Disconnect the A/C pressure (ACP) sensor connector.
7. Disconnect the CAM position solenoid valve connectors (right/left).
8. Disconnect the manifold air pressure (MAP) sensor connector.
9. Disconnect the EVAP canister purge solenoid valve connector.
10. Disconnect the injectors connectors.
11. Disconnect the ignition coil connector.
12. Disconnect the camshaft position sensor (CPS) connectors (right/left).
13. Remove the ignition coil. Refer to Ignition Coil Replacement (See: Ignition Coil > Removal and Replacement).
14. Detach the PCV clips from the PCV hose.
15. Remove the PCV hose from the cylinder head cover.
16. Remove the cylinder head cover bolts.
17. Remove the cylinder head cover (1).
Installation Procedure
1. Install the cylinder head cover (1) with the gasket.
2. Install the cylinder head cover bolts and tighten to 8 Nm (70.8 lb in).
3. Install the PCV hose to the cylinder head cover.
4. Attach the PCV clips to the PCV hose.
5. Install the ignition coil. Refer to Ignition Coil Replacement (See: Ignition Coil > Removal and Replacement).
6. Position the engine wiring harness and connect the related sensor and actuator connector.
7. Connect the oil switch wiring connector.
8. Connect the A/C compressor connector.
9. Connect the manifold air temperature (MAT) sensor connector.
10. Connect the A/C pressure (ACP) sensor connector.
11. Connect the CAM position solenoid valve connectors (right/left).
12. Connect the manifold air pressure (MAP) sensor connector.
13. Connect the EVAP canister purge solenoid valve connector.
14. Connect the injector connectors.
15. Connect the ignition coil connector.
16. Connect the camshaft position sensor (CPS) connectors (right/left).
17. Connect the battery negative cable
May 26, 2019 at 4:15 AM
