valve clearence
2002 NISSAN FRONTIER
19,900 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
BONESMIKE
  • 21 POSTS
I have the truck listed above dual overhead cams. had a new head with new bolts and chin 4 months later the pin sheared causing the chain not to turn. did this hit the valves since the timing chain failed or is there a tolerance where it will not hit the valves?
Jan 15, 2021 at 4:22 PM
Good morning,
This has resulted in valve damage and possible piston damage. When the valve timing is off, there is no clearance for the piston and valves.
https://www.2carpros.com/articles/how-a-timing-belt-works
I would be very concerned as to why the pin broke. That tells me the cam locked up. That only happens when there is a lack of oil to the head.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Jan 16, 2021 at 1:21 AM
