Value and guarantee?
56,000 MILES
KEBE OTI
I want to buy a fairly used Hyundai Sonata, but they are saying the top gasket has been tampered with, so I want to know if I can go ahead and purchase and if de tampering with the top gasket won’t be a problem?
May 14, 2024 at 1:42 AM
KEBE OTI
May 14, 2024 at 1:45 AM
  • 110,248 POSTS
Are you referring to the head gasket? If so, what are you seeing that indicates work has been done?
Also, be careful. I suspect this vehicle has a 2.4L 4-cylinder engine. There have been a number of issues related to it. Hyundai has actually extended the warranty on them. Also, in most cases, the engine failure is catastrophic, and the engine needs to be replaced.
I attached a pic below showing what has been going on with the 2.4L. Before you make a purchase, I recommend contacting a Hyundai dealership to first see if warranty work has been done, is the vehicle still under a powertrain warranty, and consider having them inspect the work.
See pic below.
May 14, 2024 at 11:41 AM
