vacuum pod in drivers side fender
117,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
CARPETMAN1759
  • 81 POSTS
Vacuum pod is full of what looks like transmission fluid and is leaking out all over the vacuum hoses.
Aug 17, 2016 at 10:48 PM
HMAC300
  • 48,601 POSTS
check for a blocked PCV valve and system. transmission has no lines connected to engine unless it is a 350 or 400 three speed transmission.
Aug 17, 2016 at 11:16 PM
CARPETMAN1759
  • 81 POSTS
It s the stock 700R-4. It could be just oil but it does have a little tint of red in it. I pulled another one off a S-10 and it also had fluid in it. Also my four wheel drive pod under the battery tray has oil in it too. So I should check the PCV system?
Aug 18, 2016 at 3:43 AM
HMAC300
  • 48,601 POSTS
yes, it may be partially blocked and engine is putting oil in vacuum lines going to tanks. make sure PCV works well as well.
Aug 18, 2016 at 4:55 AM
