vacuum lines diagram needed
213,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
KDCHRIST
  • 39 POSTS
How many vacuum lines come from the back of the engine and where do they go?
Sep 26, 2021 at 6:03 AM
  • 110,246 POSTS
For some reason, my manuals are not providing a vacuum schematic for this vehicle. However, I was able to find a couple of things that may help.
If you look at pic 1, that shows the vacuum hoses specific to your vehicle's emissions system (EVAP). Pic 2 shows a general design that Ford uses.
Now, there should be a vacuum schematic label under the hood. If possible, take a pic of it and upload it for me to see. From that, I can tell what your vehicle came with.
Also, if you are trying to find a vacuum leak, here is a link that explains how it's done. I will also tell you that there is a vacuum hose that comes off the rear of the intake and has a 90-degree turn in it. The turn is a common failure issue due to dry rot. They crack and leak.
Here is the link:
Let me know if this helps.
Sep 27, 2021 at 12:23 PM
KDCHRIST
  • 39 POSTS
I need to pursue some other issues with this truck that I now have 225,500 miles on the truck. Last summer I started pulling codes p0011 p0021 and p0435 and p0420. I replaced the timing chains and guides etc., and new phases and VCT valves. The truck runs fine but I am still pulling the same codes. any suggestions?
Jun 10, 2022 at 4:32 AM
  • 110,246 POSTS
Sorry to hear you are still dealing with this. The codes are somewhat interesting. Two of them deal with a catalytic converter issue, and the other two (which I believe you already know) deal with variable timing.
Since you have already replaced the components related to the timing, it is likely a short or open circuit keeping the P0011 and P0021 stored. Which would lead me to follow testing designed to pinpoint the specific cause.
I have attached them below. Take a look through them and let me know if you are comfortable performing them. Also, the catalytic converter codes are likely indicating a need for replacement. One is a temperature indicator and the other indicates the converter is operating below threshold.
Take a look through these and let me know your thoughts.
Jun 10, 2022 at 1:11 PM
KDCHRIST
  • 39 POSTS
Could any or all of these codes be caused by a bad muffler?
Jun 26, 2022 at 1:50 AM
  • 110,246 POSTS
The muffler itself shouldn't change anything because it is after the catalytic converters and oxygen sensors. You do have a P0420 which is related to the catalytic converter operating under the threshold. Most times, that is simply a faulty converter. However, if there is an exhaust leak before the converter (5.4L often have exhaust manifold leaks) it can cause the system to think there is a lean fuel mixture and set codes.
At the exhaust manifolds, a leak on these often times sounds like a tick when the throttle is pressed. Have you ever noticed anything like that? You could hear it at idle, but if it is a small leak, it may not be too noticeable.
Note that P0435 is also catalytic converter-related (temp). Are these codes still showing and have you replaced the converters?
Jun 26, 2022 at 1:38 PM
KDCHRIST
  • 39 POSTS
I finally got around to tracing out the wiring. I found the problem fairly quickly. There was a broken wire on the bank2 cam ting sensor. I bought a new plug and wired it in, and I am code free. Now I am ready for inspection in Feb of 2023 here in DE. Thank you so much for your input.
Dec 6, 2022 at 2:15 AM
  • 110,246 POSTS
Thanks for the update. It's appreciated and will likely help others in the future. Regardless, I'm glad to know you found the problem and were able to repair it.
Feel free to come back at any time in the future if you have questions or need help.
Dec 6, 2022 at 7:22 AM
