Vacuum line diagram needed?
22,000 MILES • 0.5L • V8 • 2WD • MANUAL
RITZO
Need a vacuum line diagram specific to the 350 quadrajet 4 barrel. The car listed above is an SS. It has all factory material 22,000 miles. Also has an electrical solenoid with a vacuum hose.
Sep 8, 2023 at 3:34 AM
  • 110,246 POSTS
Because of the model year, I basically have little to nothing. I attached what I was able to find for the air injection and the deceleration valve. I know there has to be one for the vacuum advance. Usually, that is a ported vacuum and comes from the carb.
Take a look at what I attached. Let me know if you have any specific questions, I'll try my best to help.
Sep 8, 2023 at 12:35 PM
RITZO
I believe what you are showing is from a 73 that we used to call a smog pump. I do not have that.
Sep 8, 2023 at 8:43 PM
  • 110,246 POSTS
Wow, that looks great!!! Most hoses looked connected. Are there certain ones you are having an issue with?
Also, the pics I sent indicated 1972, so I'm not sure. See pic 1 below.
I was able to find two more schematics in a different manual. One is for the vacuum advance and the other is for the EGR. (see pics 2 and 3)
Let me know if they help at all.
joe
Sep 9, 2023 at 1:24 PM
RITZO
I went to jegs yesterday a purchased 3 manuals for the Nova. Some help but not a 100% so I will figure it out or attend some car shows that have the same setup.
Sep 9, 2023 at 11:20 PM
  • 110,246 POSTS
Sorry I couldn't get more for you. I hope you are able to find what is needed. The car show idea is actually a good one.
If there is anything other, I can help with, let me know.
Sep 10, 2023 at 12:16 PM
