Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer Sport Trac
Engine
Vacuum Hose Diagram
Vacuum line broke, A/C only will blow out defrost?
2002 FORD EXPLORER SPORT TRAC
340,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
JOEY BREWER
MEMBER
1 POST
I need a vacuum line diagram to fix vacuum line.
Apr 1, 2025 at 12:51 PM
Experienced Mechanic
Hello Joey,
Yes, this is a common problem, here is a guide that should be able to help you fix it:
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Here are the HVAC vacuum line diagrams as requested. Check out the images (below). Let us know if you need anything else.
Image (Click to enlarge)
Apr 2, 2025 at 5:19 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
