How to remove throttle body?
161,472 MILES
TIMOTHY GARNER
How to take off throttle body? Vacuum line.
Jun 23, 2021 at 3:56 AM
Here is a guide that will help with removing the throttle body off a similar vehicle:
https://www.youtube.com/watch?v=StA9YXMgcBw
Below you will find the process from the manual on how to remove the throttle body on this vehicle.
Please run through this material and let us know if you have other questions. Thanks
Jun 23, 2021 at 6:05 AM
TIMOTHY GARNER
How to take plastic cover behind throttle body off vacuum line in the back?
Jun 23, 2021 at 8:17 AM
TIMOTHY GARNER
How to take off plastic cover behind throttle body?
Jun 23, 2021 at 8:26 AM
Can you get some pictures of what you are dealing with? That will help us find this specific part in the manual as it is not part of the throttle body process so it is going to be listed somewhere else but seeing it will help identify it.
Also, which engine do you have?
Jun 23, 2021 at 8:31 AM
