Vacuum leak where EGR is
150,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
WILL REY
  • 31 POSTS
I was checking the long term fuel trim and short term fuel trims.
The short term is at 0.
The Long term is at like 6-7%.
I did a smoke test on the truck. It seemed that between the EGR and Were it mounts on was leaking some smoke i am guessing bad gasket or incorrect torquing.
I checked the manual said 18 ft lbs of torque on the mounting bolts. so I did one side and the other side. Did not want to torque up it just kept spinning and not getting any tighter.
any advice on how i can get that screw to torque right, or should i look for another screw at a junk yard? lol. on that EGR gasket should i get a new one or use some gasket sealer ?
Feb 20, 2017 at 5:35 AM
WILL REY
  • 31 POSTS
f-150 4.6L XLT 2005 2WD Automatic.
Feb 20, 2017 at 5:37 AM
SATURNTECH9
  • 30,869 POSTS
If the threads are stripped you can get a heli coil to repair the threads.I would just get a new gasket.
Feb 20, 2017 at 2:24 PM
