idling rough when in park and while sitting at stoplights
73,889 MILES • 3.0L • V6 • 2WD • AUTOMATIC
06RANGER2
I’ve had this truck about 5 months and just within the last 3 months I’ve noticed the truck idling rough when in park and while sitting at stoplights/in traffic. Also when you rev the engine, it gets up to about 3,000 RPM’s and the truck just shakes. I’m thinking it’s either a vacuum leak or a bad sensor, maybe fuel injectors. Any help is appreciated.
Mar 26, 2021 at 1:09 AM
More then likely this is a vacuum leak. Here is a guide that will help find this leak:
Also, here is a video if that is a better help.:
https://youtu.be/4ktw1X4W_-k
If this checks out then we can move on but we will need to check for codes as well,
If it is a sensor issue we should have some codes however this sounds like a vacuum leak so I suspect you will find something there. Let us know what you find. Thanks
Mar 27, 2021 at 12:00 PM
