Code PS173, vacuum leak?
147,922 MILES • 2.4L • 4 CYL • AUTOMATIC
ISIS HOWELL
I'm not sure how to find the vacuum leak for code PS173.
Jan 28, 2024 at 6:03 AM
  • 110,246 POSTS
As far as locating a vacuum leak is concerned, here is a link that explains how to check:
As far as the code is concerned, usually, they start with P0. I suspect that was a typo, but when I checked for a P0173, it wasn't listed for this model.
Could you confirm the code for me?
joe
Jan 28, 2024 at 12:48 PM
ISIS HOWELL
The code showed P2173.
Jan 29, 2024 at 11:40 AM
  • 110,246 POSTS
That works. LOL The code is related to a large vacuum leak. If in fact it is a leak, you will be able to find it using the link I attached above.
On the other hand, if there are no leaks found, then suspect it could be a few things. For example, a faulty MAP sensor, wiring issues, the PCM itself, or even the throttle body.
I attached diagnostics below specific to the code. Take a look through them and let me know if you are comfortable performing them.
Jan 29, 2024 at 12:23 PM
