Vacuum leak and lean running?
279,000 MILES • 5.4L • V8 • 2WD
PAUL MENDENHALL
I have a 2003 e350 that has a vacuum leak and lean running issues. Codes show cylinders 3,5,8 misfire and running lean. My first step (I believe) is to find the leak. But I can't find a complete vacuum diagram to find and repair the leaks. I've replaced the spark plugs and coils. How do I best search for the leaks?
Sep 27, 2025 at 2:13 AM
  • 55,709 POSTS
Here is a video that can show you how to find the leak, also I know there is a large vacuum hose at the rear of the intake that is difficult to get to so check that first, also check the PCV hose as well.
https://www.youtube.com/watch?v=LRKWV4Are5c&t
and
https://www.youtube.com/watch?v=xN5pcM-5bso
both of these videos show different techniques, that both do a good job finding vacuum leaks.
Sep 28, 2025 at 4:04 AM
