IAC note sounds like vacuum leak
262,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
KIMBERLEY72
Replaced crank sensor and IAC note sounds like vacuum leak. No codes no prior issue.
Dec 12, 2016 at 6:11 PM
HMAC300
  • 48,601 POSTS
check for a vacuum leak like broken hose/off etc. also, check fuel pressure with a gauge auto parts rent it. check for duct work between air cleaner and engine for holes/ off. See link.
Dec 12, 2016 at 11:59 PM
STEVE W.
  • 15,404 POSTS
Check over all the vacuum lines, especially the ones that run through the firewall, with that many miles you may have a cracked/broken line. Very easy to knock one off.
Dec 13, 2016 at 12:00 AM
