Vacuum hose fell off, will not turn on with battery charge?
2,000,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
RANDOMUSERNAME
Hey, I'm having a few issues with my vehicle listed above and if I'm being honest, I really don't know much about engines.
1. i found what I think is a vacuum line burned through and not attached to anything on either end.no idea where it goes.
2. even though the battery has a charge when I put the key in it won't even turn on.
Before it completely stopped working there was some electrical flickering and glitching. From what I checked out on YouTube, it looked like an ignition switch problem? but after finding the vacuum tube idk. i have pics as well.
I appreciate your thoughts.
Aug 15, 2023 at 4:27 PM
STEVE W.
  • 15,394 POSTS
The vacuum line wouldn't cause it to not start, it won't run right with it off, but it would still start. The no start sounds more like a low or bad battery or dirty connections. Try these as a starting point:
Aug 15, 2023 at 5:05 PM
