Full diagram of the vacuum systems needed
177,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
NATE1985
My car has a vacuum line that is broken/missing the rest of it, on the rear end. It comes from the rear driver's side, over to the passenger's side, curves up and right when it curves back down, it's broken, and the rest is missing. I need to know what it goes to and a full diagram of the vacuum systems, so that I can thoroughly go through and double check all vacuum lines. Thank you
Apr 17, 2022 at 5:41 AM
  • 110,251 POSTS
I don't have a full schematic for the vacuum hose routing. Usually, there is a label under the hood indicating it.
If that isn't the case, I need more information. Is this under the hood or is it near the rear of the vehicle by the fuel tank?
Let me know and also, if you could provide a pic of it, that may help me identify it.
Additionally, let me know what the remaining portion is attached to. When you say rear end, are you referring to the rear differential/axle?
Apr 17, 2022 at 2:37 PM
