Vacuum
150,000 MILES • V8 • 4WD • AUTOMATIC
RNDYMN
Can a vacuum problem cause 4wd not to engage and ignition not to function some times ( crank shaft position )
Jan 31, 2016 at 5:16 AM
CATAFINA
  • 167 POSTS
If its not starting up could be the crankshaft position sensor, for the vacuum I doubt it on the 4WD
Jan 31, 2016 at 6:51 AM
HMAC300
  • 48,601 POSTS
make sure your anit theft isn't engaged for no start. if no manual look online
Jan 31, 2016 at 11:07 PM
